poI3DViewCtrl RotateZ
Rotates the contents of the current window about the Z axis.
poI3DViewCtrl_handle RotateZ angle
HyperView Tcl Modify
This command rotates the contents of the current window about the Z axis.
- angle
 - Degrees of rotation.
Error
Returns 0 if successful, otherwise an error code.
