poI3DViewCtrl SaveView
Captures the current view parameters and saves it to a memory view with the given name.
poI3DViewCtrl_handle SaveView view_name
HyperView Tcl Modify
This command memorizes the current view settings with a given name. If no name is specified, a default name will be given for the view.
- view_name
 - The name of the view.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
window_handle GetViewControlHandle viewctrl_handle
viewctrl_handle SaveView "view name"
puts "Current View: [viewctrl_handle GetCurrentView]"
hwi CloseStackError
Returns an error if the view control handle is invalid.
