poIContourCtrl GetShowMidsideNodeResults
Gets the state of the "Show Midside Node Results" option for the contour control.
contour_handle GetShowMidsideNodeResults
HyperView Tcl Query
This command returns the state of the Show Midside Node Results option for the contour control.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Get the Show Mid-side Node Results
set state [contour_handle GetShowMidsideNodeResults]
hwi CloseStackError
A bool should always be returned.
