poIContourCtrl GetThresholdMinEnableState
Gets the threshold minimum enable state (true/false).
poIContourCtrl_handle GetThresholdMinEnableState
HyperView Tcl Query
This command retrieves the threshold minimum enable state (true/false).
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myResultName GetContourCtrlHandle myContourName
myContourName GetThresholdMinEnableStateError
Returns the threshold minimum enable state (true/false), or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
