poIContourCtrl GetValueList
Gets the list of values associated with a node or element selection set.
poIContourCtrl_handle GetValueList
HyperView Tcl Query
set t [clock clicks]
hwi OpenStack;
hwi GetSessionHandle sessh$t
sessh$t GetProjectHandle projh$t
projh$t GetPageHandle pageh$t [projh$t GetActivePage]
pageh$t GetWindowHandle winh$t [pageh$t GetActiveWindow]
winh$t GetClientHandle animh$t
animh$t GetModelHandle modelh$t [animh$t GetActiveModel]
modelh$t GetResultCtrlHandle resh$t
resh$t GetContourCtrlHandle c$t
set sid [modelh$t AddSelectionSet element];
modelh$t GetSelectionSetHandle s$t $sid;
s$t SetSelectMode "all"
s$t Add all;
c$t GetValueList $sid
hwi CloseStackError
Returns 0 if successful, otherwise an error code.
