poIContourCtrl GetValueFilter
Gets the contour value filter string.
contour_handle GetValueFilter
HyperView Tcl Query
This command retrieves the value filter string used for the contour.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Get the value filter
set vfilter [contour_handle GetValueFilter]
hwi CloseStackError
Returns an empty string if the filter is not applied.
