poICrossSectionPlanar SetClipAbove
Toggles the current direction for the cross section.
poICrossSectionPlanar_handle SetClipAbove state
HyperView Tcl Modify
This command toggles the current direction of the clipping surface for the cross section. Set to "True" to clip above the section surface, or "False" to clip below.
- state
 - The state for the current clipping direction.
Returns an invalid handle.
