poICrossSectionPlanar SetColor
Sets the cross section color.
poICrossSectionPlanar_handle SetColor color
HyperView Tcl Modify
This command sets the cross section color.
- color
 - The section cut color. If the section color override in enabled, the section geometry is drawn in this color.
Returns 0 if successful, otherwise an error code.
