poICrossSectionPlanar SetCrossSectionDisplayMethod
Sets the display method to the cross section.
poICrossSectionPlanar_handle SetCrossSectionDisplayMethod display_method
HyperView Tcl Modify
This command sets the display method to the cross section.
- display_method (string)
 - The display method: "Clipping Plane", "Cross Section Only", and "No Clip".
Returns 0 if successful, otherwise an error code.
