poICrossSectionPlanar SetCrossSectionOnly
Sets the cross section only state.
poICrossSectionPlanar_handle SetCrossSectionOnly state
HyperView Tcl Modify
This command sets the cross section only state.
- state
 - Set to 'true' to make the cross section visible, otherwise set to 'false' to make the cross section not visible.
Returns 0 if successful, otherwise an error code.
