poISection SetCrossSectionOnly
Sets the cross section only state.
poISection_handle SetCrossSectionOnly state
HyperView Tcl Modify
This command sets the cross section only state.
- state
 - If the cross section is visible, the state is true. If the cross section is not visible, the state is false.
Returns 0 if successful, otherwise an error code.
