poISection SetGridSpacingY
Sets the distance between each grid line on the local Y axis for a Planar section type.
poISection_handle SetGridSpacingY distance
HyperView Tcl Modify
This command sets the distance on the local Y axis in generic model units for a Planar section type.
- distance
 - The distance between two grid lines.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetSectionHandle section_handle 1
section_handle SetGridSpacingY 1.0
hwi CloseStackErrors
None.
