poISection SetDeformMode
Toggles the deformable section mode.
poISection_handle SetDeformable deformable
HyperView Tcl Modify
- deformable
 - Set to true to enable the deformable section cut mode. Set to false for planar section cuts.
Returns 0 if successful, otherwise an error code.
