poISection SetOrientation
Sets the section's orientation plane for a Planar section type.
poISection_handle SetOrientation plane_normal
HyperView Tcl Modify
This command sets the section's orientation plane for a Planar section type.
- plane_normal
 - The orientation plane normal as a string.
Returns 0 if successful, otherwise an error code.
