Add an Analysis
Use the Analysis tool to add an analysis to the model.
                From the Project Browser right-click on the
                        Model label (or any system of your choice) and
                    selecting Add > analysis.
                The Add Analysis dialog is displayed.
 - Select the type of analysis to add.
                If you selected Uses data and definition file, complete the steps below:
- Select how to add the analysis.
 - Depending on the method selected, use the fields to create a new file, or browse to select an existing file.
 - Assign a variable name and label to the analysis.
 - Specify a definition name for the system.
                Click OK to close the window or
                        Apply to continue creating entities.
                The analysis is added to the model.
