Adding a New Analysis Data File and a New Definition File
- From the Add Analysis dialog, activate the Uses data and definition files radio button and click Next.
 - Activate the New data file radio button and click Next.
 - Activate the New definition file radio button and click Next.
 - Click the New Data File browser icon.
 - Select a path and file name and click Save.
                Click the New Definition File broswer icon.
                The Select Definition File dialog is displayed.
 - Assign a definition name to the definition file (or accept the default name).
 - Assign a type for the definition file (if necessary).
                Assign a variable name to the analysis.
                The variable name is required and cannot be changed after it is defined.
                Assign a label to the analysis.
                The analysis label can be changed at any time.
 - Click OK to close the window and add the analysis to the model or Apply to continue creating analyses.
