Adding an Inline Analysis to the Current Model
                Right-click on the Model label and select Add > Analysis.
                The Add Analysis dialog is displayed.
 - Activate the Inlined in model file radio button and click Next.
                Assign a variable name to the analysis.
                The variable name is required and cannot be changed after it is defined.
                Assign a label to the analysis.
                The system label can be changed at any time.
 - Assign a definition name to the analysis.
 - Click OK to close the window and add the analysis to the model or Apply to continue creating inline analyses.
