An option is used to customize an entity definition within an analysis. Options can
        perform operations such as turning entities on or off, or converting joints in an analysis
        from compliant to non-compliant.
            When you select the Options tab on the Analysis panel, a list
                of the options belonging to the current analysis is displayed. Each analysis has a
                compliant option by default. This option can be used to toggle the state of joints
                within the analysis. The joint or bushing within the analysis should be modeled
                within an *if(Op_Compliant == "Yes") loop in the MDL language
                using a text editor.
                From the Project Browser, select an analysis.
The Analysis panel is displayed.
                Select the Options tab.
                Specify whether to make the system compliant or non-compliant from the
                    drop-down menu.
Selecting
Yes makes all the compliant joints in the
                    system compliant while selecting
No makes all compliant
                    joints non-compliant.
In addition to converting compliant joints, MotionView can turn other entities on or off in a system
                        according to predefined system settings. For example, MotionView can turn off specific entities such as springs or
                        stabilizer bars when the system is made non-compliant.
Note:
                            - The Compliant option is applied to all subsystems beneath the
                                current system.
                            - The Compliant option can be overridden for individual joints in the
                                    Joints panel.
                            - Not all joints can be compliant. The rules for converting joints
                                from compliant to non-compliant are built into each model using the
                                MDL language.
                            - See *Option() in the MDL Language
                                Reference for more information on creating options.
