H3D Output
Command ElementDefines an H3D output command.
<H3DOutput
switch_on = {"TRUE | FALSE"}
[ increment = "integer" ]
[ format_option = {"MODAL | NODAL | AUTO"} ]
[ stress_option = {"NONE | TENSOR"} ]
[ strain_option = {"NONE | TENSOR"} ]
[ gpstress_option = {"NONE | TENSOR"} ]
[ start_time = "real" ]
[ end_time = "real" ]
[ elemforce_1d = {"TRUE | FALSE"} ]
[ nodal_velocity = {"TRUE | FALSE"} ]
[ nodal_acceleration = {"TRUE | FALSE"} ]
[ linear_animation = {"TRUE | FALSE"} ]
/>Attributes
- switch_on
- "TRUE" creates H3D file, "FALSE" does not.
- increment
- Controls how often data is written to the H3D file. For example, "2" means data is written at every second step.
- format_option
- Select from "MODAL", "NODAL" and "AUTO" (Default = AUTO).
- stress_option
- Select from "NONE" and "TENSOR" (Default = "TENSOR").
- strain_option
- gpstress_option
- start_time
- Specifies the start time for writing the H3D. The following conditions must be met:
- end_time
- Specifies the end time for writing the H3D. The following conditions must be met:
- elemforce_1d
- Select "TRUE" or "FALSE" to enable or disable 1D element force export to the H3D file.
- nodal_velocity
- Select "TRUE" or "FALSE" to enable or disable nodal velocity output to the H3D file.
- nodal_acceleration
- Select "TRUE" or "FALSE" to enable or disable nodal acceleration output to the H3D file.
- linear_animation
- Select "TRUE" or "FALSE" to enable or disable linear analysis mode shapes to be output to the H3D file.
- The H3DOutput command produces an H3D file for animation.
- When the model includes flexible bodies, the format_options "MODAL", "NODAL", and "AUTO" provide control over file size.
- If format_option = "MODAL", the mode shape data and time history of the modal participation factors are stored in the H3D file. This approach incurs a computational cost during visualization as nodal results must be computed from modal results on the fly.
- If format_option = "NODAL", nodal data are stored for each time frame instead. This usually produces larger H3D files than the "MODAL" option, however, it increases the visualization performance.
- If format_option = "AUTO", the most efficient option in reducing the H3D size is automatically determined.
- If stress_option = "NONE", then element stress results are not output to the H3D file. This option reduces the H3D file size for large models if stress results are of no interest.
- If stress_option = "TENSOR", the element stress results are written in tensor format to the H3D file. HyperView calculates the vonMises and other parameters from the stress tensor.
- The strain_option and gpstress_option work in the same way as the stress_option.
- For the gpstress_option, grid point stresses are written in tensor format to the H3D file.
- If the FlexH3D file does not have element stress mode shapes, then the stress_option is ignored.
- If the FlexH3D file does not have grid point stress mode shapes, then the gpstress_option is ignored. Grid point stresses must be explicitly requested in OptiStruct during the CMS analysis.
- For the attributes nodal_velocity and nodal_acceleration to work properly, flex_vel_acc_output = "TRUE" must be set in the Output: Results command. If it is not, nodal_velocity and nodal_acceleration are not be written to the H3D file.
- When linear_animation is set to "TRUE", there has to be a linear analysis in the simulation. The linear analysis generates <results_name>_linz.mrf, which is a requirement for the linear animation output to the H3D file.
- The start_time and end_time can be used to reduce the size of the H3D in cases where the H3D generated is very large. You can specify a window of interest where you would like to view the animation and skip the H3D generation for the remaining time in the simulation.
