Sensor: Event
Command ElementModifies a Sensor_Event model element.
<Sensor_Event
id = "integer"
type = "EXPRESSION"
expr = "motionsolve_expression"
compare = { "GE" | "LT" | "EQ" }
value = "real"
error_tol = "real"
usrsub_dll_name = "NULL"
usrsub_param_string = "USER([[par_1[,...][,par_n]])"
usrsub_fnc_name = "custom_fnc_name"
value = "real"
error_tol = "real"
[ verbose = { "TRUE" | "FALSE" } ]
/>Attributes
- id
- Element identification number (integer>0). This number is unique among all Sensor_Event elements.
- expr
- Specifies an expression that defines the sensor event. Use this parameter only when TYPE = EXPRESSION. Any valid run-time MotionSolve expression can be used.
- usrsub_param_string
- The list of parameters that are passed from the data file to the user defined SENSUB. Use this keyword only when TYPE = USERSUB is selected.
- usrsub_dll_name
- Specifies the path and name of the DLL or shared library containing the user subroutine. MotionSolve uses this information to load the user subroutine SENSUB in the DLL at run time.
- usrsub_fnc_name
- Specifies an alternative name for the user-written subroutine SENSUB.
- compare
- Defines the comparison measure.
- value
- The sensor event threshold. An event is said to occur when the expression or user subroutine meets the comparison criterion with respect to value.
- error_tol
- Defines the error tolerance for detecting an event. The sensed value is required to be within this tolerance of the threshold value, before an event is generated by the solver.
- verbose
- Use this attribute to control how often an action message is written to the screen and log file when a sensor is triggered.
<Sensor_Event
id = "100"
expr = "MOD(AZ(22,11),PI)-PI/2"
