Body: Flexible
Command ElementModifies a flexible body element.
<Body_Flexible
id = "integer"
label = "string"
is_user_damp = " { True | False } "
cdamp_expr = "string"
usrsub_dll_name = "string"
usrsub_param_string = "string"
usrsub_fnc_name = "string"
rigidified = " { True | False } "
/> Attributes
- id
- Element identification number (integer>0).
- is_user_damp
- Changes how the damping coefficient for each mode is specified.
- cdamp_expr
- Modifies the state dependent expression used to define the damping coefficient for each mode. Use this parameter only when is_user_damp = "TRUE". Any valid run-time MotionSolve expression can be provided as input.
- usrsub_dll_name
- Changes the path, name, or both for the shared library that contains your user subroutine. MotionSolve uses this information to load the user subroutine specified by usrsub_fnc_name in the library at run time. Use this keyword only whenis_user_damp = "TRUE".
- usrsub_param_string
- Changes the list of parameters that are passed from the data file to the user written
subroutine. Use this keyword only when is_user_damp
= "TRUE".The syntax for this attribute is:
USER([[par_1],[par_2],...,[par_n]]) - usrsub_fnc_name
- Modifies the name of the user subroutine function specified in the model element.
- rigidified
- Converts the flexible body to a rigid body.
The following example illustrates the use of the <Body_Flexible> command element to modify the damping of a flexible body defined in the model:
<Body_Flexible
id = "30102"
cdamp_expr = "IF(FXFREQ-100:1.0,1.0,1.0)"
- In the case where you specify is_user_damp = "TRUE" and both cdamp_expr and a user subroutine (usrsub_param_string, usrsub_dll_name, usrsub_fnc_name) are defined, MotionSolve gives precedence to the cdamp_expr over the user subroutine.
