Model Instrumentation
The outputs and storage frequencies must be set to get enough information for post-processing results.
Variables To Save
- Springs
- Save all spring and beam elements (except for spring of spot welds)
- Interfaces
- Save all contact interfaces (except for TYPE 2)
- Rigid Bodies
- Measure the displacement and force inside specific rigid bodies
- Section, Rigid Wall and Monitored Volume
- Save all TH outputs
- Mass
- /ANIM/MASS
- Nodal mass variation
- /ANIM/NODA/DMAS
- Plastic Strain
- /ANIM/ELEM/EPSP
- von Mises
- /ANIM/ELEM/VONM
- Hourglass
- /ANIM/ELEM/HOURG
- Specific energy
- /ANIM/ELEM/ENER
- Velocity
- /ANIM/VECT/VEL
- Contacts
- /ANIM/VECT/CONT
- Force on rigid wall
- /ANIM/VECT/FOPT
