Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup
during the computation.
Generates animation files containing results according to the keywords specified. The keywords are specified in the
topics within Animation and Post-processing Output Files.
Engine Keyword Generates animation files containing averaged grip point strain data calculated by bilinear extrapolation using shape
functions from the integration point results. The average value at each node is calculated by each element
which connected to this node.
Engine Keyword Generates animation files containing averaged grip point stress data calculated by bilinear extrapolation using shape
Engine Keyword Generates animation files containing simple average GPS data. The average value at node is calculated by the mean
stress of all elements, which are connected to this node.
Engine Keyword Generates animation files containing volume based averaged GPS data, which is done by the relative element volumes
(connected to same node use Vi/V total).
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling
or quasi-static), different options to control the implicit computation, different implicit time step method and
implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF)
and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature,
etc.) in state file (STA-File).
/ANIM/GPS/STRAIN/TENS Engine Keyword Generates animation files containing averaged grip point strain data calculated by bilinear extrapolation using shape functions from the integration point results. The average value at each node is calculated by each element which connected to this node.
/ANIM/GPS/STRESS/TENS Engine Keyword Generates animation files containing averaged grip point stress data calculated by bilinear extrapolation using shape functions from the integration point results. The average value at each node is calculated by each element which connected to this node.
/ANIM/GPS1 Engine Keyword Generates animation files containing simple average GPS data. The average value at node is calculated by the mean stress of all elements, which are connected to this node.
/ANIM/GPS2 Engine Keyword Generates animation files containing volume based averaged GPS data, which is done by the relative element volumes (connected to same node use Vi/V total).
