Output Database
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
Groups | Keyword | Object saved | Variables/Descriptions |
Time Histories | Global variables | IE, KE, TE, TTE, DTE, RKE, CE, HE, EFW, XMOM, YMOM, ZMOM, MASS, DT, SIE, TER, DTE_REL, VX, VY, VZ | |
/TH/SUBS | Subsets | IE, KE, XMOM,
YMOM, ZMOM, MASS, HE TURBKE, XCG, YCG, ZCG, XXMOM, YYMOM, ZZMOM IXX, IYY, IZZ, IXY, IYZ, IZX, RIE, KERB, RKERB, RKE |
/TH/PART | Parts |
IE, KE, XMOM, YMOM, ZMOM, MASS, HE TURBKE, XCG, YCG, ZCG, XXMOM, YYMOM, ZZMOM IXX, IYY, IZZ, IXY, IYZ, IZX, RIE, KERB, RKERB, RKE |
/TH/NODE | Nodes | DX, DY, DZ,
VX, VY, VZ, AX, AY, AZ VRX, VRY, VRZ, ARX, ARY, ARZ, X, Y, Z, TEMP REACX, REACY, REACZ, REACXX, REACYY, REACZZ |
/TH/SHEL | 4-node shells | F1, F2, F12,
Q1, Q2, M1, M2, M12, IEM, IEB, OFF, THIC, EMIN, EMAX, EPSD,
E1, E2, E12, SH1, SH2, K1, K2, K12, USRi
(i=1,60) USRII_JJ (II=1,60; JJ=1,99), USRII_JKK (II=1,60; J=1,4; KK=1,99) SX_JJ, SY_JJ, SXY_JJ, SYZ_JJ, SZX_JJ (JJ=1,99) |
/TH/SH3N | 3-node shells | F1, F2, F12,
/TH/BRIC | Solids | OFF, SX, SY,
SZ, SXY, SYZ, SXZ, LSX, LSY, LSZ, LSXY, LSYZ, LSXZ, IE,
DENS, BULK, VOL, PLAS, TEMP, PLSR, DAM1, DAM2, DAM3, DAM4,
DAM5, DAMA, SA1, SA2, SA3, CR, CAP, K0, RK, TD, EFIB, ISTA,
VPLA, BFRAC, WPLA, SFIB, EPSXX, EPSYY, EPSZZ, EPSXY, EPSXZ,
EPSYZ SXi, SYi, SZi, SXYi, SYZi, SXZi (i=1,8) LSXi, LSYi, LSZi, LSXYi, LSYZi, LSXZi (i=1,8), USRi (i=1,60) SXijk, SYijk, SZijk, SXYijk, SYZijk, SXZijk, EPijk (i=1,3; j=1,9; k=1,3) SXiUk, SYiUk, SZiUk, SXYiUk, SXZiUk, SYZiUk, EPiUk (i=1,3; k=1,3) SXiDk, SYiDk, SZiDk, SXYiDk, SXZiDk, SYZiDk, EPiDk (i=1,3; k=1,3) USR1_ijk, USR2_ijk, USR3_ijk, USR4_ijk, USR5_ijk, USR6_ijk, USR7_ijk, USR8_ijk, USR9_ijk (i=1,3; j=1,9; k=1,3) E11_ik_j, E12_ik_j, E13_ik_j, E22_ik_j, E23_ik_j, E33_ik_j (i=1,3; k=1,3; j=1,200) S11_ik_j, S12_ik_j, S13_ik_j, S22_ik_j, S23_ik_j, S33_ik_j (i=1,3; k=1,3; j=1,200) |
/TH/QUAD | 2D quads | OFF, SX, SY,
SZ, SXY, SYZ, SXZ, IE, DENS, BULK, VOL, PLAS, TEMP, PLSR,
DAM1, DAM2, DAM3, DAM4, DAM5, DAMA, SA1, SA2, SA3, CR, CAP,
K0, RK, TD, EFIB, ISTA, VPLA, BFRAC, WPLA,
SFIB LSX, LSY, LSZ, LSXY, LSXZ, LSYZ |
/TH/BEAM | Beams | OFF, F1, F2, F3, M1, M2, M3, IE | |
/TH/TRUSS | Trusses | OFF, F, IE, A, L, PLAS | |
/TH/SPRING | Springs | OFF, FX, FY, FZ, MX, MY, MZ, LX, LY, LZ, RX, RY, RZ, IE, F1, F2 | |
/TH/NSTRAND | Multi-strand | OFF, FX, LX, IE | |
/TH/ACCEL | Accelerometer | AX, AY, AZ, WX, WY, WZ | |
/TH/SECTIO | Section | FNX, FNY, FNZ, FTX, FTY, FTZ, M1, M2, M3, WORK, WORKR, FX_error, MX_error, MX, MY, MZ, F1, F2, F3, CX, CY, CZ | |
/TH/CYL_JO | Cylindrical joints | FX, FY, FZ, MX, MY, MZ, F, M | |
/TH/MONVOL | Monitored
volume Airbag |
MASS, VOL, P,
A, T, AO, UO, AC, UC, CP, CV, GAMA AO1, BO1, UO1, MO1, HO1 AO2, BO2, UO2, MO2, HO2 AO3, BO3, UO3, MO3, HO3 AO4, BO4, UO4, MO4, HO4 AO5, BO5, UO5, MO5, HO5 AO6, BO6, UO6, MO6, HO6 AO7, BO7, UO7, MO7, HO7 AO8, BO8, UO8, MO8, HO8 AO9, BO9, UO9, MO9, HO9 AO10, BO10, UO10, MO10, HO10 |
/TH/RWALL | Rigid wall | FNX, FNY, FNZ, FTX, FTY, FTZ | |
/TH/RBODY | Rigid body | FX, FY, FZ, MX, MY, MZ, RX, RY, RZ, FXI, FYI, FZI, MXI, MYI, MZI | |
/TH/FXBODY | Flexible body | IE, KE, EFW, DE | |
/TH/GAUGE | Gauges | P, IE, DENS | |
/TH/INTER | Interface | FNX, FNY,
FNZ, FTX, FTY, FTZ, SFW (only Interface types 14
and 15) Following variables are only for interface types 7, 10 and their Sub interfaces (/INTER/SUB): |FNX|, |FNY|, |FNZ|, ||FN||, |FX|, |FY|, |FZ|, ||F||, MX, MY, MZ |
/TH/FRAME | Frame | OX, OY, OZ,
R11, R12, R13, R21, R22, R23, R31, R32,
R33 VX, VY, VZ, VRX, VRY, VRZ, AX, AY, AZ, ARX, ARY, ARZ |
/TH/MODE | Flexible body local modes | D, V, A | |
Time Histories (Part definitions) | /THPART/GRBEAM | Beam group | IE, KE, XMOM,
/THPART/GRBIC | Brick group | IE, KE, XMOM,
/THPART/GRQUAD | Quad group | IE, KE, XMOM,
/THPART/GRSH3N | 3-node shell group | IE, KE, XMOM,
/THPART/GRSHEL | Shell group | IE, KE, XMOM,
/THPART/GRSPRI | Spring group | IE, KE, XMOM,
/THPART/GRTRUS | Truss group | IE, KE, XMOM,
Other Output Databases | /ACCEL | Node | Used to define accelerometers using a node and skew system. |
/CLUSTER | Brick or spring | Used to output force and moment for an assembly of brick or spring elements for post-processing and failure control. | |
/GAUGE | Node or shell | Used to define pressure gauge. | |
/GAUGE/SPH | Node or shell | Used to define SPH pressure gauge. | |
/INTER/SUB | Node, surface or interface group. | Used to output the contact forces for sub-interfaces. | |
/SECT | Brick, shell, truss, spring. Triangle or beam group | Used to output force and moment for specific section. | |
/SECT/CIRCLE | Brick, shell, truss, spring. Triangle or beam group. | Used to output force and moment for section which are defined with circle. | |
/SECT/PARAL | Brick, shell, truss, spring. Triangle or beam group. | Used to output force and moment for section which are defined with parallelogram. |
