Interfaces
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
Each of these interfaces was developed for a specific application field. However, this application field is not the only selection criteria. Some limitations of the different algorithms used in each interface can also determine the choice.
Interface Types
Contact Treatment | Types | Application | Description | |
Kinematic Constraint | Tied | /INTER/TYPE2 | Change of mesh density (solid) | Tied connection between two Lagrangian materials. |
Penalty method | Slide / Void | /INTER/TYPE3 | Use of TYPE7 is recommended | Sliding with void
opening and friction between two Lagrangian
surfaces. Symmetric computation (J. Hallquist algorithm). |
Slide / Void | /INTER/TYPE5 | Use of TYPE7 is recommended | Sliding with void
surfaces. Non-symmetric computations (main-secondary algorithm). |
Slide / Void | /INTER/TYPE6 | User-defined contacts | Impact contact between two rigid surfaces. | |
Slide / Void | /INTER/TYPE7 | Solid contact impact at all speeds | Multipurpose
interface. Can be used in place of TYPE3 or TYPE5. Node to Segment contact. |
Slide | /INTER/TYPE8 | Stamping applications | Drawbead line. | |
Tied / Void | /INTER/TYPE10 | Special purpose interface | Tied contact + void opening (optional) | |
Slide / Void | /INTER/TYPE11 | For beams, bars or springs | Edge to Edge contact. | |
Slide / Void | /INTER/TYPE14 | For MADYMO to Radioss coupling. | Hyper-ellipsoid to nodes contact | |
Slide / Void | /INTER/TYPE15 | For MADYMO to Radioss coupling. | Hyper-ellipsoid to elements contact | |
Slide / Void | /INTER/TYPE19 | Solid contact impact at all speeds and for beams, bars or springs. | General contact
interface. Node to segment contact and Edge to Edge contact. Equivalent to one interface TYPE7 + one interface TYPE11. |
Slide / Void | /INTER/TYPE21 | For stamping | Specific interface between a non-deformable main surface and a secondary surface designed for stamping. | |
Slide / Void | /INTER/TYPE23 | For airbag | Soft penalty contact for airbag. | |
Slide / Void | /INTER/TYPE24 | This contact interface can replace interface TYPE3, TYPE5, or TYPE7. | General contact interface | |
Slide / Void | /INTER/TYPE25 | General contact interface with linear stiffness. | Multipurpose interface that can replace interface TYPE3, TYPE5, TYPE7, or TYPE24 | |
Lagrange multiplier method | Tied | /INTER/LAGMUL/TYPE2 | Change of mesh density (solid) | Tied contact between main and secondary nodes. |
Slide / Void | /INTER/LAGMUL/TYPE7 | Solid contact impact at all speeds | multi-usage impact interface between a main surface and a list of secondary nodes. | |
Slide / Void | /INTER/LAGMUL/TYPE16 | meshes with 8-node or 16-node thick-shell or 20 bricks | Contact of impact between nodes and external surfaces. | |
Slide / Void | /INTER/LAGMUL/TYPE17 | meshes with 8-node or 16-node thick-shell or 20 bricks | Contact of impact between external surface of two brick groups. | |
Automatic Penalty Lagrange | Slide / Void | /INTER/LAGDT/TYPE7 | Solid contact impact at all speeds | Same behavior as TYPE7 with constant minimum time step. |
Hertz Formulation | Slide / Void | /INTER/HERTZ/TYPE17 | meshes with 16-node thick-shell or 20 bricks. | Using Hertz contact theory to describe impact between external surface of two brick groups. |
ALE | Tied | /INTER/TYPE1 | Fluid-structure interaction | Boundary between an ALE material and a Lagrangian material. |
Slide / Void | /INTER/TYPE9 | Fluid-structure interaction | ALE/Lagrange, with void opening and free surface. | |
FLUID / FLUID | /INTER/TYPE12 | Fluid to fluid contact | Connects two fluid
meshes with free, tied or periodic options. ALE or EULER or LAG/ALE or EULER or LAG |
Slide / Void | /INTER/TYPE18 | Fluid-structure interaction | Coupling between a Lagrangian material an ALE material. |
