/STATE/BEAM/AUX
Engine Keyword Describes the internal variable state for beam.
/STATE/BEAM/AUX
  1. A block /BEAM/AUX is written into each state file, for each part declared into /STATE/DT, including the additional internal variables which might be needed for the state of the beams to be completely restored.
  2. No block is written for a part if its beams do not use any additional internal variables.
