Fill Hole
Use the Fill Hole tool to fill holes on mesh parts.
- If starting from an optimized design in Inspire, first copy the part and then select Paste Without Reference in the Model Browser.
On the PolyMesh ribbon, select the Fill Hole tool.
- Mouse over a hole until you find a preview that you like, then click on the preview to fill the hole with mesh. Repeat the process for all holes you want to fill.
Click Apply
to confirm and accept the filled holes.
