Use the Sculpt tool to modify the original mesh using one of several brush
tools.
If starting from an optimized design in Inspire,
first copy the part and then select Paste Without
Reference in the Model Browser.
On the PolyMesh ribbon, select the Sculpt tool.
Select a brush type on the guide bar.
- Smooth brush: Locally smooths material along the
direction of the brush. (Use the Smooth tool to smooth the entire
part.)
- Round brush: Add or remove material along the
- Planar brush: Creates a planar mesh along the
Note: Holding the Shift key while sculpting will
temporarily switch to the Smooth brush.
Select a part to sculpt. The brush influence zone is shown as a red
circle.
Click-and-drag the mouse over the part to sculpt it. You can adjust the size
and strength of the brush using the sliders on the guide bar to achieve
different effects.
Double right-click to exit the tool.
You can use the PolyNURBS Fit tool after sculpting to
create a new PolyNURBS part on top of the existing mesh geometry.
