Remove
Use the Remove tool to automatically find small disconnected regions of a mesh part and delete them.
- If starting from an optimized design in Inspire, first copy the part and then select Paste Without Reference in the Model Browser.
                On the PolyMesh ribbon, select the Remove tool.
 - Select a part.
 - Disconnected regions that will be removed are shown in red. Hold Ctrl to add or remove from the selection.
                Click Apply
. The small disconnected regions are removed.
