Induction machines – Motor Factory – Design environment
Computation of inter bar impedance
For induction machines, inter bar impedance (resistance and inductance) is computed by considering characteristics defined in Motor Factory.
However, while exporting the model into Flux® 2D or into Flux® Skew, inter bar impedance will remain constant, even if a parametric study is performed in Flux® environment. The topology parameter as well as the temperature variations won’t impact the inter bar impedance.
