Induction machines - Motor Factory - Export environment
Do NOT use the export to Flux3D for induction machines
The export of induction machines with squirrel cage from FluxMotor to Flux 3D is not yet finalized and it should not be accessible from the GUI of Motor Factory / Export environment.
Unfortunately, the icon of this export has not been hidden in the GUI of FluxMotor 2022.3 / Motor Factory / Export area.
It is highly recommended to NOT use this export because there are still several critical issues that need to be fixed.
| (1) - Do NOT use the export to Flux3D for induction machines |
