Induction machines – Motor Factory – Export environment
Defining the end ring reference temperature fails (Manual mode)
The reference temperature which is set to define the end ring impedance in manual modes is not considered while exporting a project to Flux 2D or Flux Skew (ref.: FXM-15145).
This issue has been corrected.
End-ring impedance – Reference temperature is not well applied
While exporting a model from FluxMotor® to Flux® 2D or Flux® Skew environment, if the end-ring impedance has been defined with the “constant computation mode” (= user mode) instead of the automatic one, the reference temperatures set by the user are not used in the resulting Flux® project. Instead, the default values are automatically considered (ref.: FXM-13713).
