Script Factory
The find/replace dialog box has an issue
In Script Factory, the find/replace dialog box must be closed when the end of the file is reached. When the search reaches the end of the file, the only way to restart from the beginning is to close the dialog window, reopen and enter once again the data (ref.: FXM-15138).
This issue has been corrected.
