Custom Blocks
The Activate library includes customizable blocks that you can define for a variety of systems.
A custom block can be fully defined including its block ports, parameters and simulation function. The nature of this block enables you to define the behavior of a system as you construct your model. The block is inlined when initially defined, and not referenced to a library. If you wish to save a custom block for reuse, you can export it in a variety of ways and add it to a library.
