Define this block with C commands and functions.
        The CCustomBlock provides a generic interface for specifying the block's properties
            and defining its simulation function based on C commands and functions. The simulation
            function is specified in C code and stored as a block parameter. The C code is used
            during simulation.
                From the Palette Browser, select . Drag and drop the block into your diagram and double-click
                    it.
The block dialog appears with tabs to define the Ports, States,
                    Parameters, SimFunction and other advanced properties for the
                    block.
                On the Ports tab, enter the number of input and output
                    ports for the block, enter a name for each port, then click OK.
                On the States tab, enter the state of the block with
                    respect to its initial continuous condition, initial state derivative, initial
                    discrete state, and number of initial object states, then click
                            OK.
                On the Parameters tab, enter the number of parameters
                    for the block. For each parameter, enter a name, value, and type, then click
                            OK.
                On the SimFunction tab, generate a code skeleton, enter
                    the simulation function for your block, then click OK. The skeleton provides the essential
                    framework for the C function that interfaces with inputs, outputs and events.
                    Additional options:
                    - Check the syntax of the C function with the check C
                            code button.
                    - Export a DLL with the generate dll and convert
                        button.
                On the Advanced tab, enter the number of modes and
                    zero-crossings for the block, select the activation mode: always
                        active, initially active or
                        standard, then click OK.
