Define this block with OML commands and functions.
        The OmlCustomBlock block provides a generic interface for specifying the block's
            properties and defining its simulation function based on OML commands and functions. The
            simulation function is specified as OML code and stored as a block parameter. The OML
            code is used during simulation.
                From the Palette Browser, select . Drag the block into your diagram and double-click it.
The block dialog appears with tabs to define the Ports, States,
                    Parameters, SimFunction and other advanced properties for the
                    block.
                On the Ports tab, enter the number of input and output
                    ports for the block, enter a name for each port, then click OK.
                On the States tab, enter the state of the block with
                    respect to its initial continuous condition, initial state derivative, initial
                    discrete state, and number of initial object states, then click
                            OK.
                On the Parameters tab, enter the number of parameters
                    for the block. For each parameter, enter a name, value, and type, then click
                            OK.
                On the SimFunction tab, generate a code skeleton, enter
                    the simulation function for your block, then click OK. The skeleton provides the essential
                    framework for the OML function that interfaces with inputs, outputs and
                    events.
                On the Advanced tab, enter the number of modes and
                    zero-crossings for the block, select the activation mode: always
                        active, initially active or
                        standard, then click OK.
