Add/Edit Mold
Create and edit a mold that contains the cast part and all components.
Microdialog Options
Adjust the margins of the mold and define the position, material, temperature, and dimensions.
Option | Description | |
Move |
Click ![]() |
Resize |
Click ![]() |
Trim |
Click ![]() |
Material |
Select the material. |
Material Viewer |
Click ![]() |
Temperature |
Enter the temperature. |
X |
Enter the dimension along the x-axis. |
Y |
Enter the dimension along the y-axis. |
Z |
Enter the dimension along the z-axis. |
Roughness |
Select the roughness of the mold surface finish.
Specular provides a polished mold surface with low friction between liquid and mold. Normal is the regular mold finish and the default.High provides a poor surface finish with high friction between liquid and mold. |
Coating |
Select the thickness of the foundry coating. A thin layer changes the HTC value of the mold to 880 (W/(m2*K)). A medium layer changes the HTC value of the mold to 630 (W/(m2*K)).A thick layer changes the HTC value of the mold to 500 (W/(m2*K)). |
