Add/Edit Sleeve
If you haven't designed any sleeves in a CAD tool, you can create and edit virtual sleeves in Inspire Cast.
You can only create sleeves over risers that were created in Inspire Cast. If you imported a riser from CAD, import the sleeve too.
Microdialog Options
Define the sleeve type, temperature, and thickness of the sleeve. If you selected an exothermal sleeve, define the burning time, ignition temperature, and released heat.
Option | Description | |
Material Viewer |
Click ![]() |
Sleeve Type |
Select a Generic isothermal or Generic exothermal sleeve. |
Temperature |
Enter the temperature. |
Thickness |
Enter the thickness. |
