Decimate Mesh
Use the Decimate tool to coarsen mesh based on a defined element size.
From the Discrete ribbon, click the Decimate tool.
Figure 1. - Select surfaces or parts to consider.
Enter a size threshold.
Any input elements that have edge lengths smaller than this size value are decimated.
Enter a feature angle constraint.
Any input elements that have a defined angle less than this value are decimated. For inputs with higher curvature, define a higher angle to loosen the constraint.
- Click Decimate.
