Repair Surface Mesh
Use the Repair tool to find, review, and fix issues in the mesh.
Note: This tool only works on visible surfaces.
From the Mesh ribbon, click the
Repair tool.
Figure 1.Note: This tool is also available on the Discrete ribbon for working with FE or mixed geometry.
- Optional:
Click
on the guide bar to update check thresholds.
- Optional:
Click Find to update the checks.
Since updates are done automatically, clicking Find is required only if checks are not in sync or visibility has been updated.
- Select a check to work on from the first drop-down menu on the guide bar.
Select an option to fix the issues from second drop-down menu.
This list will change based on the selected check.
Navigate through and review each error.
Increase or decrease the number of layers around patches of failed
elements by clicking
or
on the guide bar.
Review the next or previous patch of failed elements by clicking
or
on the guide bar.
Define any additional options then fix the errors in the following ways:
- Hover over a red highlighted error patch and left-click to fix that particular issue using the options defined on the guide bar.
- Click Fix All on the guide bar to fix all errors at once.
Note: If any error checks can not be fixed using the options provided in the Surface repair tool, isolate surfaces and visibly review mesh issues.
