Remesh Tessellated Models
Use the Remesh to create new surface mesh on converted geometry.
The Remesh tool works for tessellated geometry. If the input is b-spline geometry, first convert to discrete geometry using the Convert tool.
Imported Nastran .stl files can consist of poor quality mesh. After converting to discrete geometry, it's helpful to remesh the model. The rest of the options used to edit geometry work better on a good quality mesh.
Note: You have the option to retain the surface mesh you create here when performing batch meshing.
  1. From the Discrete ribbon, click the Remesh tool.
  2. Select surfaces, parts, or elements to remesh.
  3. Define meshing options in the dialog.
  4. Click Mesh on the guide bar.
