Review Exploration Summaries
Once an exploration is complete, review a summary of design variable and output response values in tabular format.
Optimization Summary Table Data
The optimization summary table shows the design variable values along with the calculated objective and constraint values for each run.
Column Color Coding
- White Background/Black Font
- Feasible design
- White Background/Red Font
- Violated design
- White Background/Orange Font
- Acceptable design, but at least one constraint is near violated
- Green Background/White Font
- Optimal design
- Green Background/Orange Font
- Optimal design, but at least one constraint is near violated
Apply Variables to Model
Apply design variable settings from a run to the model.
- In the Summary Table of the Result Explorer browser, right-click a run and select Apply variables to model from the context menu.
- In the Update Variables dialog, click Yes.
Load Results and Plots
Visualize contours, animations, and plots for each run in the modeling window.
