In this tutorial, you will learn how to assemble the vehicle for full vehicle simulations using Assembly Wizard and
how to attach the driver using Task Wizard.
In this tutorial, you will learn how to define a path and velocity or acceleration profile, set up a feedforward steering
controller to follow a path, and set up a feedforward traction controller to follow a velocity or acceleration profile.
In this tutorial, you will learn how to define end conditions for a maneuver or a sub-event, write parametric expressions,
and to define events as multiple sub-events executed sequentially
In this tutorial, you will learn how to access the Leaf Spring Builder utility, populate a leaf spring model with
data, save the data, generate a MotionView file of the leaf spring, open the model in MotionView, create a test of the model, and exercise the test using the utility.
In this tutorial, you will learn how to load the MBD-Vehicle Dynamics Tools preference file in MotionView, build a tire model, run the model in MotionSolve, and view the simulated results.
In this tutorial, you will learn how to use the Soft Soil Tire and Road model, create moving carpet road graphics,
run the model in MotionSolve, and view the simulation results.
In this tutorial, you will learn how to add the Altair Driver in any model built outside the Assembly Wizard Library
and run the full vehicle events available in MotionView.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
MV-8000: Open Loop Events
In this tutorial, you will learn how to assemble the vehicle for full vehicle simulations using Assembly Wizard and how to attach the driver using Task Wizard.
MV-8001: Path and Velocity Following
In this tutorial, you will learn how to define a path and velocity or acceleration profile, set up a feedforward steering controller to follow a path, and set up a feedforward traction controller to follow a velocity or acceleration profile.
MV-8002: Multi-Maneuver Events
In this tutorial, you will learn how to define end conditions for a maneuver or a sub-event, write parametric expressions, and to define events as multiple sub-events executed sequentially
MV-8003: Gear and Clutch Control
In this tutorial, you will learn how to interface gear clutch control for vehicles with manual transmission.
MV-8004: n-Post Event
In this tutorial, you will learn how to add a 4-Post event for the Sedan car model, run the model in MotionSolve, and view the simulation results.
MV-8050: Leaf Spring Builder
In this tutorial, you will learn how to access the Leaf Spring Builder utility, populate a leaf spring model with data, save the data, generate a MotionView file of the leaf spring, open the model in MotionView, create a test of the model, and exercise the test using the utility.
MV-8100: Tire Modeling
MV-8500: Use the Truck Library
In this tutorial, you will build a full truck model with a driver, add events to the model, and view the reports.
MV-8600: Road Reference Marker
In this tutorial you will learn how to modify the road property file and road reference marker to position a plank road in a single tire model.
MV-8700: Soft Soil Tire and Road Model
In this tutorial, you will learn how to use the Soft Soil Tire and Road model, create moving carpet road graphics, run the model in MotionSolve, and view the simulation results.
