Multi Sweep
Sweep multiple profiles along a path to create a solid or surface. Create a new part or combine, subtract, or intersect the swept shape with existing parts.
On the Geometry ribbon, select the Multi
Sweep tool.
Note: The tool may be hidden in a dropdown menu. To access the dropdown menu, you can do one of the following:- Click and hold the currently displayed tool (Sweep, Pipe, or Loft).
- Select
at the lower right corner of the
The guide panel appears.
Choose the entity type that you'd like to create:
- Solid: Sweep as a solid.
- Surface: Sweep as a surface.
By default, for Profile, Select
mode is automatically turned on.
- Select a face or closed sketch.
(Optional): Select
so that clicking an edge will also select
edges connected to the profile.
Note: To deselect, hold down Ctrl while clicking. To clear all selected features, in the microdialog click Clear Selection. -
Choose a Path:
- Click the Select button.
Select a sketch, a curve, or an edge. The plane in which the profile
lies must intersect the path.
If
the path extends beyond the profile, the sweep can occur in both
directions.
(Optional): Select
edges connected to the path.
Choose a profile Orientation:
- Perpendicular (default): Orient the swept shape perpendicular to the path.
- Parallel: Orient the swept shape parallel to the path.
Choose the type of sweep:
- Arc Length Profiles: If the parametrization of the path is uneven, evenly space the isoparms along the path for a less stretched shape.
- Arc Length Path: If the parametrization of the path is uneven, evenly space the isoparms along the path for a less stretched shape.
Choose a Result type:
- Combine/Merge: Combine or merge the swept shape with the existing parts.
- Subtract (only available for Solids): Carve out the swept shape from the existing parts.
- Intersect (only available for Solids): Retain only the intersecting portions of the swept shape and the existing parts.
- New Part: Create a new part from the swept shape.
Choose a Merge method:
- All Parts (default): Merge the swept shape with all parts that touch the swept shape.
- Parts: Select the radio button to merge the swept shape with selected parts. Then select the parts that you’d like to merge the swept shape with.
- Click Apply.
