Modify Results Plot
Adjust the display attributes for the results plot.
- On the Project Tree, open the Analysis Workbench.
On the Analysis Workbench
toolbar, click
(Results plot).
In the drop-down menu, click the desired plot.
The Legend dialog will open and the chosen contour plot will appear in the modeling window.
Figure 1. -
Control the contour bounds.
Use the Max and Min text
boxes to set upper and lower contour bounds.
Figure 2. -
Use the
icon to lock Max and Min contour
bounds.
Use the
icon to show the Max and Min labels in the
modeling window.
- Under Image, set the contour colors.
Use the
icon to show deformed shapes in the modeling window.
Change deformation scale factor.
Click the
(Change max deformation) icon.
- In the dialog, clear the Default check box and either adjust the slider, enter a scale value into the text box, or use the arrows to increment the scale factor as desired.
- Optional: Clear the Default check box and enter a scale value of 1.0 to set deformation to true scale.
Click the
View/adjust the Animation.
Click the
icon to play the animation.
The slider will show the current frame of the animation:
Figure 3. -
Click the
icon to stop the animation.
Use the Animation Speed and Animation
Step sliders to adjust the speed and frames displayed in
the animation.
Figure 4.Note: These sliders will only be active when the animation is playing.
Click the
