Squeak and Rattle Response
View results for squeak and rattle analysis.
- In the Project Tree, open the Squeak and Rattle workbench.
In the workbench toolbar, click
(Response).
- In the dialog, select the sampling point set you want to review the response.
Select the response type in the drop-down menu.
- If the response type is Minimal gap or Maximum tangential displacement, click on one of the sampling points in the graphics to view the plot of selected response over time.
Use the slider to select Display point size.
The modeling window will update to display the chosen results.
- Click Close.
