Results Export
You can export deformed shape in ssg/stl format for all parts in a given Project Tree branch.
To access the dialog, in the Project Tree right-click any Structural analysis Results branch and select Export from the context menu.
- You can export both true deformation and scaled deformation. To export scaled
deformed shape, clear the True deformation check box.
Figure 1. - You can export deformed mode shape for modal analysis by right-clicking on the
Results branch and selecting
Export in the context menu.
You must plot results to activate this function.To export a deformed shape for modal analysis, you should enter a maximum deformation as the displacements are normalized in modal analysis.
