SS-V: 5000 Coupled Analysis - Bimetallic Beam Under Thermal Load
Test No. VNL01 Find temperature at the material interface and maximum deflection of the beam.
Definition
The layers of materials are: 0.05 x 0.5 x 10 inch
- Properties: Material 1
- Value
- Modulus of Elasticity
- 1.e+7 psi
- Poisson's Ratio
- 0
- Coefficient of Thermal Expansion
- 14.5e-6 1/F
- Thermal Conductivity
- 5 BTU/(hr-in-F)
- Properties: Material 2
- Value
- 1.e+7 psi
- Poisson's Ratio
- 0
- 2.5e-6 1/F
- 5 BTU/(hr-in-F)
The temperature at the top and bottom surfaces is 400 degrees F.
Results
Ref Solution* | SimSolid | % Difference | |
Temperature at Contact [def-F] | 400.00 | 400.00 | 0.00% |
Max Deflection [in] | 0.90 | 0.89 |
-0.88% |
* Ref Solution is 1D model
