SS-V: 5090 Bushing Stiffness
Test No. VNL10 Find the rotation of cylinder subjected to a moment of 10 N-m along its length.
Definition
- X
- 100 N/m
- Y
- 100 N/m
- Z
- 100 N/m
- Rot X
- 10 N-m/rad
- Rot Y
- 10 N-m/rad
- Rot Z
- 10 N-m/rad
The units are SI.
Dimensions: D = 443.3 mm, H = 231 mm
- Properties
- Value
- Modulus of Elasticity
- 2.05e11 pa
- Poisson's Ratio
- 0.3
Results
Reference [Target Value]* | SimSolid | |
Rotation of Cylinder (rad) | 1 | 1 (57.3 degrees) |
*The reference is calculated by hand using a rotation of 1 radian about the cylinder axis.
