Macros
You can record your session actions (in the Editor) as macros to replay them at a later time using the Macros menu.
Start, Stop and Run Macros
  1. When you are ready to begin recording your session, click Tools > Macro > Start Recording.
    Compose begins recording your session.
  2. To stop recording, click Tools > Macro > Stop Recording.
  3. To play your current macro, click Tools > Macro > Run Current Macro.
  4. To save the current macro, click Tools > Macro > Save Current Macro and enter the name to use.
Select and Run a Saved Macro
  1. Click Tools > Macro > Select and Run.
    The Select and Run dialog opens.
  2. Use the drop down menu to select the macro to run.
  3. If desired, set the macro to run a specific number of times to run.
  4. Click Run.
Remove a Saved Macro
  1. Click Tools > Macro > Remove Macro.
    The Remove Macro dialog opens.
  2. Use the checkboxes to select the macro to remove.
  3. Click Remove.
